Piledriver wrote:For the oversize valve the t4 ones work IIRC.
I also recall mention of a Mercedes ex valve option, but that was 38mm and sodium cooled.
The trw valves work fine in stock t4 apps but that was with single springs.
The only time I recall ever seeing tip pitting also had adjuster pitting, I suspect it was due to low zddp oil.
(The adjusters>tip is also high load/point contact lubrication)
I want to say 9mm stem 36mm dia TRW replacements for the 2.0 Porsche heads exist, but I always went with 8mm stem and new guides.
One could always use the sodium cooled ones but $$$ and need turned down a touch @36mm.
All valid points, tho often hammered stem ends/adjusters go with weak hydros being the culprit, same as pitted lifter problems in a solid lifter motor, folk jump straight down the makers throat without thinking, blame any one but themselves, when it's usually down to too wide a valve gap allowing the lobe to crash the lifter beyond the opening ramp, same with a collapsed hydro lifter, allows bashing the adjuster into the valve tip too hard.
If ever a race motor was built for solid lifters and zero gap valve lash, it is the Wasser, mine are no noisier than a hydro motor even when hot, so we'll controlled is the coolant expansion factor
Suited to chromo push rods, that and noise damping by the coolant jackets, I lost 3db on our race noise checks just going over to the Wasser, it used the same silencer from my previous air cooled motor, don't sound like much, but 3 db is a considerable reduction.
