Sorry this took so long. I thought I posted to both forums. The document for strut rebuild for 411/412 with Audi cartridges is done and is at least temporarily available for view as I tweak a few things and find a place to put it permanently.
It is fitting that today's date is ....4-12.... Very Happy
Here is the link to the document in my dropbox.
https://www.dropbox.com/s/oa14cvfncmyre ... s.doc?dl=0
This is just a test. If its useful and can be read this way I will get a disc to Everett so it can be uploaded to the archive.
Bear in mind. This document could not be easily built here on the Samba. Its 111 pages, about 19,000 words of text and hundreds of photos and diagrams. If that sounds excessive....just bear in mind that it spans 25 years of mods and variations to the front struts.
Lots of things tried, lots of failures and several ways to go with each section of the mod.
I only included versions that worked but definitely warn of things that can fail. It has materials shopping list and painting notes.
It is a Microsoft word document. This was the easiest format to work in so that everyone could pretty much open it up.
It was done in Windows 7 64 bit. If need be I will make a translational doc for those with earlier word.
EDIT...sorry had to fix something...try it now
Ray
The link has been renewed at 8:20 pm central
VW 411 and 412 Audi Strut Rod document (test)
Hulken
Re: VW 411 and 412 Audi Strut Rod document (test)
Is the link working?
Hulken wrote:Is the link working?
It works now. It must have been a spacing change when I copied the link from the post in the Samba. I copied the new link directly from the share listing on dropbox.
Thank you for letting me know there was an issue Hulken!
Ray
