After my AMR500 1600cc engine, I want to build an engine with more HP, and Torque..
Torque is the key word...
The engine will be placed in my 64' Splitscreen.
Car Specs: IRS/944 disc brakes , 911 steering rack, and is bagged.
The handling is very good
What I have for engine parts now:
- T4 Cu Case
- stock crank
- stock rods
- webcam #119
- strait cut gears
- webcam lifters
- all new bearings +gaskets
- stock 2.0 cylinders
- 911 cooling system
- melling 30 mm oil pump
- Ford edis 4cil coil package
- crank pulley + 36-1 trigger wheel
- 1700cc heads (suitable now for 2.0) (bit upgrade on the intake)
- RVS Custom T4 turbo exhaust (Need to modify it)
- Alfa V6 single throttle house (bit bigger then from a golf vr6)
- Innovate MTX-L AFR
- Oil thermostat (on the engine, not external)
- external oil cooler with fan
- all small engine case parts
- GB intake manifolds
- 44mm wategate
- TD04-13T-4 Turbo
- GFB mach 1 BOV
Target +/- 150HP...
For EFI: Megasquirt 3.0 KDFI
If you have good advice feel free to post, this is my second engine build..
I will try to keep this topic updated.. I'm not much a writer.. so don't expect very long stories
Edit: on the parts list
