The case halves will fit into my ultrasonic cleaner if I can get all the stud bolts out, hence the need to remove them. The case-to-head studs were "easy" to get out, only took a bit of heat and a few attempts each to get them loose. But these ones, the main bearing clamp studs are proving to resist persuation. I have tried heating, then it struck me that that may not be the way to go about it due to the fine pitch threads. Does anyone have any tricks to share?
To ensure we are talking about the same bolts, here is a picture of the first of the stubborn ones.
