Greetings to all: Latest challenge Shift TUBE Bracket
REZ60
Post by REZ60 »
Hi Happy with 1967 Bug I purchased. Swing axle was difficult to get into 3rd and 4th GEAR,,, Previous owner supplied a shift tube BRACKET and bushing. Found THE BRACKET unusable with a broken ring. Bushing was completely missing. I can not see any access to install the repacement bracket in the tunnel. Since the bracket has mounting bolts stamped into the bracket there has to be a way to get it into the tunnel. Appreciate all replys
vwjunkie60
Re: Greetings to all: Latest challenge Shift TUBE Bracket
Post by vwjunkie60 »
you tube it. from what everyone tells me you have to cut out the old bracket and weld in the new bracket
Bruce2
Post by Bruce2 »
With the shifter off, clean the top of the tunnel. Surrounding the hole you should see a series of dimples where the spot welds are. Drill these out and the bracket should drop away. Since you have the shift rod out already, it shouldn't be to hard to fish it out through the inspection hole at the rear under the back seat.
Or, pull it out the front hole by the front beam.
