2L Typ 4
Typ 11 Beetle
2L Typ 4
Post by Typ 11 Beetle »
Not the cleanest install,but makes a lot of Fun!
2L Typ 4
T3/T4 Turbo
Ahnendorp Header
0,55 bar
with 102 Octane 225 HP
petew
Re: 2L Typ 4
Post by petew »
Man, that's really cool. Well done for fitting it all in! Currently struggling with the same issue. :)
Udo Airbus
Re: 2L Typ 4
Post by Udo Airbus »
Nice build!
Can you give more specs on the engine/turbo?
I'm building almost a same combo..
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, 1915cc
Wally
Re: 2L Typ 4
Post by Wally »
Great! I think its a neat install.
Next step intercooling and more boost?
Typ 11 Beetle
Re: 2L Typ 4
The Engine is not so special, FK 89 Camshaft, 1700CC Cylinderheads,Copper gaskets,around 8,0/1,
Mahle Pistons, polished original Connecting Rods, bigger Valves,dual Valvesprings.
tonyorlo
Re: 2L Typ 4
Post by tonyorlo »
Nice! Like the other guys I'm going the same route, and your hp number is exactly where I want to be. Did you do any port work to your heads? Are you running forged 94mm Mahles?
Re: 2L Typ 4
FK89 cam??
madmike
Re: 2L Typ 4
Post by madmike »
Hey Steve,that's same thing I thought :wink: ..FK89 is a hugeass cam :lol:
Typ 11 Beetle
Re: 2L Typ 4
Yes , it´s a FK 89. It was an attempt , i bought the Long Block with the original 914 Cam but it produces a lot of heat and not much power. Then i thought ,try the opposit way ,together with bigger valves and less CR. With 0,6 bar boost without chargecooler i am now at 230 HP. It rev´s over 7000 RPM . Boost starts at 3000 RPM. The Turbo is to big for my combo , it´s like driving an old 930.
Typ 11 Beetle
Re: 2L Typ 4
tonyorlo wrote:Nice! Like the other guys I'm going the same route, and your hp number is exactly where I want to be. Did you do any port work to your heads? Are you running forged 94mm Mahles?
Yes
Re: 2L Typ 4
Yes
Nice!
just registered you are probably running bus pistons, so basically stock bottom end.
Udo Airbus
Re: 2L Typ 4
Hi,
What gearbox are you running?, thanks
Typ 11 Beetle
Re: 2L Typ 4
Udo Airbus wrote:Hi,
Nothing special, it's a AT Gearbox with 0,89 forth gear welded synchrocone, heavy duty retainer nut and thrust Plate.
Udo Airbus
Re: 2L Typ 4
Ok thanks! I have the same gearbox, only stock..
Can you advise me where to buy those parts?
Thanks!
Typ 11 Beetle
Re: 2L Typ 4
I bought my parts at Weddle.
