So I want to build a 1679 for my Super Beetle. Stripped down my Original EA case. Looks like it's been line bored once but never thrust cut from the measurements I have taken.
Width of #1 main bearing saddle 46mm or 0.844in
#4 main bearing OD 50.55mm or 1.99in
#1 main bearing OD 65.52mm or 2.579in
#1-3 main bearing bores all measure 65.28mm or 2.57in
#4 main bearing bore 50.32mm or 1.981in
Connecting rod side clearance 0.254-.279mm or 0.010-0.011in or #s 1-3. 0.432mm or 0.017in on #4.
Just got the case cleaned up, going to bolt it back together to take more measurements this week.
This is a learning build for me. I am using the Tom Wilson book as a guide. Not going in a daily driver just a Weekend cruiser.
What camshaft should I put in this engine. I would like to run dual carbs on it as well. Probably going to keep my stock heat exchangers as its cold up here in Northern Canada.
My 1679 build thread. First engine build
Carguy89
