Prototype /one-off hubs. These are true knock-offs (gave away the plates and knock-off spinner when I sold the rears years ago). Very beefy. Remove pins (allen screws), drill and press in studs. Rotors heavily pitted, but you could probably clean them up and use them (or replace with new ones @ $89.99 ea from Jimco). These were never used! Dusty. Comes with new in the boxes Timken bearings and races, along with SKF seals ($150+ from Pacific Customs). Bummed I can use them (new ride has KK spindles). $275 shipped to west coast-ish. Thanks.
Comes with new studs/Lugs in package. Drill with 9/16 bit (37/64 is ideal), you've already got good sized pilot holes, press in and that's that. This is a fraction of what it cost for new CNCs.
I can't believe they are still available after two days. Damn CNC hubs for combos run around $1k and these are even beefier than the current offerings.
