It will not be an LS1 fire breathing Race thing, or for that matter even a street thing but a very unique vehicle for my unique needs. I'm kinda going backwards as I am finding simplicity, function and basics more appealing and drawing me back in that direction? Maybe its age? I started out running around the so cal deserts in the late60's and early 70's on a VW 36 HP pan with a couple cross grooved tires, yep we were on the cutting edge!
I'm fortunate in that I am starting with a very solid 181 with no rust. As far as 181's go the PO has done everything that is available in bolt on design. Everything for the most part that he has done is done well and clean. The nice thing is that everything he has accomplished is exactly what I would have done or would eventually want to do.
What has been done to this point:
So as it sits it has a new fresh 1776 engine
New well tuned Webber progressive carb
Electronic distributor
new aluminized exhaust
Remote oil fillter
3" Body lift kit
I haven't measured them but after market trailing arms
New Bilstiens in the back and Gas-a-justs in the front
2 Trans axles one with a C/Ratio 3rd and 4th gear
Adjustable stock 181 beam in the front
new bushings all around
New studs in the hubs
Things I have to install and build
Full cage
Front and rear bumper / guards / engine cage
Install winch
Aux lighting all the way around
Build a roof rack
possible 3 aux fuel cells
remote oil cooler and fan
some type of spare tire mount
Relocate the tail lights led's
Im sure Im forgetting something!
The car was stripped down to paint but that is where the PO ran out of gas and his project stopped. With that in mind I thought this might be the best time get the above stuff taken car of. Along the lines of paint I think Im going to take thew easy route and just mask off the interior, under the hood, and some day the engine bay and do the Raptor / Line-X Thing. The plan on the out side is to shoot a nice coat of Desert Storm tan on it and go over that with a digital camouflage look.
I need another week or two to finish up a few pre-pending projects then I'm free to jump in on the 181 project. I think it should go fairly quick as I have a bunch beer drinking shop rats that like snick in and hang out here after hours... wrenching fools! So This is a good start to a build thread and to announce just what my intentions are.
Just a warning up front guys! If you see something being done in a different way than your use to seeing that is OK! It most likely being done for a reason that will make since later on in the build. A few pics of what I am starting with. First thing is to get that exhaust up off the ground!
