El Cheapo 1678cc turbo build
930
Post by 930 »
Here’s a project thread for my 69x88 (machine in) super-low-budget-trash turbo build.
The engine in the project is a very cheap, “lottery / unknown” engine (bought for less than $500) which was built for a type of “trashcan” racing series we have over here. Supposedly the engine had just been redone, however it looked *really* rough on the outside, so I didn’t have that high hopes. It was cheap and I went and bought it off.
It had dual Kads and I sold them off from the engine, and I had an engine with about $200 invested in it. Pretty cheap base to start with. The goal is to make about 150+ bhp with basically as low of a budget as possible. Most likely not the best approach in the world, however it is a challenge I quite like though :) I can always upgrade some parts later on...
I tore the engine to take a look what it had inside. All new bearings, new followers, a welded 69mm C/W VW crank, line bored case - albeit grinded 2nd to last size - 043 stock valve heads with pretty heavy porting, new pistons and cylinders...BUT two of the cylinders had pitting as evidently water has been water in the engine at some point. The guy I bought the engine from paid for two new cylinders and a gasket kit after a bit of coughing. After all the engine was supposed to have new parts instead of rusted cylinders :)
I didn’t know which cam the engine had and even though I tore the engine down, I didn’t have any luck finding what the cam is as they typically grind all the markings off from the cam. So I did a bit of reading on cam selection – exchanged a few PM’s on various forums and went on bought an FK44 cam. Most likely a bit too aggressive, wrong selection by all standards and whatnot: but as they say: slap it in and see how it runs.
Cylinder heads are 043 castings with stock valves. I cc’d the chambers and they were 32cc’s – the guy I bought the engine from said that the heads were 36cc’s but on the same notion said he really wasn’t sure about is as he bought the engine from another guy.... Deck was at 1.5mm so that gives a total compression of 11.2. Quite a bit too high of a compression for a turbo engine...so I went and did a bit of reading on various forums, and decided to find a few cc’s on the heads. The worst I could do was to ruin the heads and I decided to take my chances as the starting point was cheap enough.I can always melt the heads for my home alu-casting experiments :)
Now the heads have 39cc’s, and there are about 0.5cc eyebrows for valve clearance in the pistons. This gives me me 9.5:1 compression with 1.5mm deck. I can’t / won’t get more cc’s from the heads as I'm pretty limited on squish area already and I don’t want to run higher deck than 1.5mm so that’s where I am at. I could of course use copper gaskets / shims under the barrels to lower compression a bit though: 0.2mm shim would give me 5cc’s → compression of 8.7:1-. However as I’ll use RE85 I "should" be OK with 9.5:1 CR. Comments welcome on this of course. Single springs with following specs: 42mm - 51kg, 40mm - 58kg, 38mm - 66kg, 36mm - 74kg, 34mm - 81kg, 32mm - 90kg, 30mm - 99kg , 28mm - 108k, 26mm - 116kg.
I have a set of CroMo pushrods that I'll cut to length and a set of cheapo 1.4:1 rockers I’ll use in this build.It will be fuel injected with a DIY ECU which goes by the name of Speeduino - an Arduino based ECU. More @ http://www.speeduino.com.
I'm not based in the US so hence some of the prices below might appear high to You :D
Currently I have invested as follows on the engine:
* Engine itself: $200
* Logmech aluminium pushrod tubes: $100 (Could have saved money with stock PR tubes)
* FK44 cam: $130
* Alumium cam gear: $40
* Lash caps: $10
* Used Garrett Disco Potato turbo: $ 150
* CroMo pushrods: $ 110
* 1.4:1 rockers: $ 175
* Schadek oil pump: $45
* 2nd hand Ford TB (54mm): $20
* Deep sump: $90
* 12-1 Trigger wheel: $15
* Aluminium pulley: $35
* Honeywell 1GT101DC Hall effect sensor: $45
* 440cc *Bosch Green* knock-off injectors: $45 (should be OK to about 220 crank hp @ 85% duty cycle with RE85)
* Speeduino ECU board and components: about $ 140
Plus some small various stuff so I have about $1350-1400 on the engine so far. Even though i'm trying to get it done pretty cheap, small stuff adds up pretty quickly. If I can get it to work with less than say $ 1500-1700 I am pretty happy with the results.
No pictures at this point but I will update the thread accordingly and I’ll try to update at least once a week.
Thanks for looking and comments welcome.
(edited: due to typo corrections and minor changes / additions)
panel
Re: El Cheapo 1678cc turbo build
Post by panel »
Speeduino ECU..... ? Never heard of it. Tell me/us more about it. Have you ran this ECU before ?
petew
Post by petew »
Like a megasquirt and runs off Tuner Studio
http://speeduino.com/wiki/index.php/Speeduino
930
Post by 930 »
Petew - thx to him - already gave the link which was also in the text above.
Never ran this ECU before, but there are a few running this and it seems to work OK. A guy from France is running a Speeduino on a Type 2 also. In French but is has pretty nice pictures to look at :) http://www.old-droppers.com/index.php?showtopic=38723 a very nicely executed project IMHO.
I think this is the best bang for the buck there is at the moment. Requires a bit of tinkering / soldering as one can't buy ready kits. However it does have pretty decent features. Of course it's not for everyone as it requires soldering and is a bit of experimental at the moment.
First and foremost Speeduino is cheap, and as this is an El Cheapo project it fits the bill nicely.
Below a list of features:
What you will get is flexible and configurable fuel and ignition management that will work for the majority of every day type setups. Currently supported features include:
16x16 3D fuel and ignition maps, with base of either TPS (Alpha-N) or MAP (Speed Density)
Supports up to 8 cylinders fuel and ignition with 4 channels of fuel and 4 channels of ignition outputs
1, 2 (Even fire only), 3, 4, 6 (even fire only) and 8 cylinders
After Start Enrichment
Rev limiting (Spark based, hard and soft)
Cranking specific enrichment, dwell timing and advance
General logging through TunerStudio
High speed tooth logging
TPS calibration through TunerStudio
Sensor calibration through TunerStudio (Coolant, IAT and O2)
Warm Up Enrichment (WUE)
TPS based acceleration enrichment
Tacho output
Fuel pump activation/deactivation (With priming)
Over dwell and over duty protection
Battery voltage compensation for dwell and injectors
Modular wheel decoder support. Included decoders:
Missing tooth (Eg 36-1, 60-2 etc)
Basic distributor
GM 7X
GM 24X
4g63 aka 4/2
'Jeep 2000'
Audi 135
Miata 99-05
Honda D17 (12+1)
Taking requests...
Open loop idle control (PWM and Stepper)
Experimental closed loop PWM idle control
Open loop boost control
Open loop VVT control
Semi-Sequential, Batch/bank, or Simultaneous injection
Deceleration fuel cut off (DFCO)
Launch control
O2 based autotune (Registered version of TunerStudio required)
panel wrote:Speeduino ECU..... ? Never heard of it. Tell me/us more about it. Have you ran this ECU before ?
930
Post by 930 »
Initially I was planning to run no intercooler / chargecooler, however after listening to suggestions and doing some reading on the topic I changed my mind. I'm getting a barrel air/liquid cooler from ebay for about $150.
As I will be running RE85 water / meth injection doesn't really help me, as RE85 is 106 octane, and methanol has only slightly higher octane rating (110?) - so no plans for water / meth injection at this point which is good from $ perspective.
mads b (dk)
Post by mads b (dk) »
Flow test your china "bosch" injectors.... I had a set? they where useless junk
Tapatalk
930
Post by 930 »
Thanks for the tip. Need to do that. Typically cheap and good are two different products. I just took a gamble with these.
mads b (dk) wrote:Flow test your china "bosch" injectors.... I had a set? they where useless junk
Tapatalk
petew
Post by petew »
Sounds like a cool setup, pretty similar to my 1600. :)
930
Post by 930 »
Pictures of the engine as bought and after a bit of cleaning during pre-assembly.
Also a pic of Speeduino with almost all of the components in place. All components not yet soldered - but soon...WIP.
petew
Post by petew »
Any update on this 930?
