Hi,
I have finally tracked down a 1964 KG, into which I intend putting a Subaru EJ25 NA engine.
The Subarugears transmission kit is a bit expensive, and I am looking to mate the stock KG trans to the Subie.
Will the stock trans handle the increased power, or need modification?
Being a 4 spd trans, will that negatively affect the driving experience?
Cheers.
KG Trans mated to Subaru EJ25 engine
Re: KG Trans mated to Subaru EJ25 engine
When you need to fix or upgrade a VW trans the Subarugears setup starts to look like a bargain in a big hurry.
I personally wouldn't trust a 6v swingaxle past ~100 hp, if you beat on it at all it will die badly.
Bruce2
The Subaru alphabet soup doesn't mean much on this VW board. What size is this engine? How much hp?toeinthewater wrote: EJ25 NA engine.
Likely you will need to source a newer gearbox. The one you have is geared for 40hp, and is full of the weakest bits VW produced.
2.5L 155 or 165 HP NA DOHC 16v 1:1 CR, 170 lb/ft TQ.
If its a later NA EJ25x about the same SOHC or DOHC.
Its basically a NA STi motor, with high compression pistons.
Any of them would mean a quick ugly death for the stock transmission in a 64, and as Bruce pointed out, be geared all wrong.
Would be great fun given a transmission built and geared to use it.
Doing that properly with a T1 VW trans would cost far more than a Subarugears setup, esp if you did the suby trans work yourself, which is apparently doable, as it doesn't require $$$$pecial tools and experience to do.
toeinthewater
Thanks for your quick, succinct replies. Subarugears it is!!
