914 big engine build
Mikedrevguy
Post by Mikedrevguy »
I'm beginning to compile the parts to build a big motor for RevWife's 914.
Looking at the AA type 4 crank - what avantage or pitfalls will there be staying with 2.0 rods vs going with type 1? How will the rod choices affect the deck?
What clearancing of a stock 914 2.0 case can I anticipate?
Any draw backs to going with an 82mm over a 78mm?
AA biral 96mm pistons/cylinders
Cam - 163/86b
Hpmx 44
What should be done to enhance cooling? Anything necessary?
This is her commuter car, fun weekend car, have fun on the 1/4 mile track.
Thoughts? Comments? Revisions..
: have stock 914 2.0 heads. What size valves would be best, were I to open them up?
Thanks in advance.
Mike
_________________
Re: 914 big engine build
Welcome to the STF!
If going stroker on a t4, the shorter 78mm stroke and a smaller rod journal make it easier to clearance, as the rods do not clear the cam lobes as on a T1: t4 lobes are much wider due to wider cylinder spacing.
A reduced base circle cam may still be helpful, but a 78mm with the EMW 2.0 liter journal should clear most everything.
A 914 transmission is not recommended for drag racing--- 1st gear cannot take the abuse of a proper launch, its supported only on one end. Think of it as a 4 speed with a granny gear.
Mikedrevguy
Thanks Piledriver. Am leaning more toward the smaller 78 stroke - just didn't want to discount anything out of hand without exploring.
any suggestion/recommendation for putting the 914 on the strip? Launch soft?
any other options?
Thanks,
Mike
Autocross tracks can be ~1/4 mile :lol:
The 914 is ~ideal for that.
sideshow
Post by sideshow »
The autocross track is closer to you than a quarter mile track! Who cares about ones ability to drive in a straight line from a light?
If you lack the ability to make left and right turns the obvious solution to middle engine linkage/901 trans is a modern front engine automatic transmission. You would be on your own for a kit but it has been done (normally using both the subaru boxer/trans combo).
There is a SubaruGears ACVW engine<>Subaru trans adapter, I have been eyeballing it myself for my 914 when it gets the 2466.
(The adapter/flywheel combo seems a bit steep but I haven't priced Kennedys adapters in years)
Buidling a ~high HP capable VW or early Porsche trans would probably cost 5X what the subaru trans would, a converted 915 or G60 is just as rediculou$$S and likely no stronger. (I think they have to be run upside down?)
Most of the cost is a one time deal (adapter/flywheel/drive stubs) so even if you DID kill a Subaru trans, you still have all the conversion parts, so you just get another victim.
The Subaru automatic is a short, fat little sucker. Not sure specs or fitment, strength, or even if an adapter exists, but having a flexplate fabbed up won't cost any more than an adapter flywheel.
(I was eyeing Audi FWD transmissions in much the same way)
