Right, before I get to the problem, no I don't want to go EFI. No, I don't want to forget it and build a stroker engine. No, I don't want to switch to blow-through carb. I absolutely appreciate the reasons why folk would suggest the above, but I want to solve the problem in front of me keeping it "as is", and not spend a fortune re-working things. Honestly, I really appreciate the effort folk put in to offering advice, I really do, so please don't take the above as me being an arse.
So... Here's the issue.
I have a junkyard drawthrough turbo setup on my stupidly low, undriveable, cambered as hell ridiculous Volksrod.
It's sucking through a Dellorto DHLA 40 via a (very dead) Garrett T3 from a Saab 900. The clever folk at the back will already see a problem, the TB0358 from a Saab 900 is dynamic sealed, and therefore no good for drawthrough. Correct! But it's came with the engine when I bought it...
(For those wondering if you can get away with a dynamic seal turbo in a drawthrough configuration: No, you can't. Not long term. Sooty dirty exhaust, oily intake, fouled plugs, weird fueling symptoms telling you that you are lean, yet the dirty plugs telling you that you're rich, detonations... Just don't do it.)
What has really killed things though is, well, my turbine housing is now essentially in more pieces than it left the factory in... There's a honking crack that goes right over the wastegate hole, with a good chunk missing there too. So, no boost for Dave
So, I have a list of turbos that are carbon sealed from factory, but can I balls find one!!
TB0319 Renault
TB0327 Pug
TB0390 Merc
TC0304 Citreon
TA0305 Renault
TB0307 Ford
TB0310 Renault
TB0308 buik
tb0309 buik
tb0317 buick
TB0346 pug
tb0360 merc
TB0369 Merc
TB0344 Ford
TB0371 / 78 / 75 Crysler / Dodge
TB0355 Dodge
TB0306 Nissan
Do you know of any others?
Now as it happens, while writing this, and email just popped up from a company that have been quite helpful as of today with a price for a backplate, thrust parts, carbon seal etc to convert my Garrett TB0358. I may have even found a compatible turbine housing. But, this thread may well help someone else, or me in the future when I kaboom things again!
So, can anyone offer any advice? Know of anything for sale? They are really thin on the ground, and trawling Ebay has revealed that so far everyone selling turbos for hte above vehicles are sticking dynamic seals in them because "They are more reliable blablabla" - despite me telling them that often a carbon seal is used for a good reason in old turbos
Thanks in advance, chaps!
