Kadron-Powered Ghia takes 2nd Bonneville Record!
FJCamper
Post by FJCamper »
Above: Mark Ortiz takes another record on Kadrons, flying RetroRacing colors.
Mark Ortiz set his 2nd Bonneville land speed record this year during the 10-13 September 2016 Bonneville World of Speed
An essential element in appreciating Bonneville records is understanding the classes. Cars are divided by four general categories, Special Construction, Vintage, Modified, and Production.
Special Construction are the cars most people associate with Bonneville. Any engine, any fuel, any body style and records of multiples of hundreds of miles per hour. But the rank and file cars that run here are closer to reality, being some version of a car you might drive on the street. To set a record, you find a class in which you can win, and you go for it. For those who think some of these records are not that fast, that you could do better driving to work Monday, we respectfully ask, how many official land speed records do you hold?
Mark set his first Bonneville class record (G/Classic Fuel Altered) on August 16th, turning 106.420 mph in his green 1968 air-cooled Ghia. His carbs were 40mm throttle body Kadrons with 30mm venturis. His engine was a mild 1.8, big valves but no special head work, just a 120 Engle cam and 8:1 compression.
After a consultation with us at RetroRacing, Mark upgraded to 10:1 compression, added 1:25 rockers, and installed 32mm venturis and 140 main jets.
Mark ran this time in" G" engine (1500-2000cc) Classic Gas Altered Coupe. This is not a special VW class, but is open to anyone in class that qualifies. He returned to the salt flats just a few days before this report and ran an official record of 113.131mph. His official top speed was 118.625.
The previous G/CGALT record was held by the "Wagon A Go Go," driven by Dave Malot with his 60 cubic inch Mazda Rotary engine.- at 94.77 mph. In a station wagon.
For economy, reliability, and performance, Mark runs Kads, like we do on our racing engines and for the same reasons.
To keep his fan speed down, Mark runs a 4.75-inch crank pulley. To keep his RPM's within reason, he races a 3.88 final drive on 28-inch diameter salt flat tires in the rear.
Two wins back to back is terrific. The big question is what records to break next year?
Slow 1200
Re: Kadron-Powered Ghia takes 2nd Bonneville Record!
Post by Slow 1200 »
good job! It must be running some serious caster shims to drive straight at those speeds with that (great looking) rake!
WickedWagens
Post by WickedWagens »
Thanks for the post FJC and thanks to Retro Racing for the help. We were able to gain an extra 7 mph with some relatively simple changes and recommendations. The speeds are not that impressive, but it was good to get the new car out, see how it handles at speed, and see how the salt is to drive on.
It was different. Nothing to gauge speed by, no body else around, just you and the machine that you have spent countless hours and way too much money on. The salt can feel loose at times. Veteran racers call it "soul searching". Not moving around enough to have to move the steering wheel, but you can feel it moving around and trying to find its way down the salt.
The engine is just a mild performance engine built for our Volkswagen 181 Thing. It is an 1807cc 76x87. The heads are stock valve, just cleaned up and mildly ported. Looking back at the build sheet the cam is an Engle 110, not the 120 I thought it was. The extra compression really helped the engine wake up and it was more responsive. The corrected altitude was 6400 ft. Now to put some power in it and see what kind of speed we can get next year. BTW I'm running 2 sets of caster shims with extra long bolts.
1968 Karmann Ghia land speed
G/CFALT 106.643 MPH G/CGALT 113.131 MPH
G/CBGALT 169.462 MPH G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH H/CBGC 94.334 MPH
H/CPRO 93.383 MPH H/CBFALT 101.282 MPH
H/CBGALT 120.591 MPH
Top Speed 174.2 MPH
WickedWagens
[BBvideo=560,315]https://youtu.be/V55FTheBTWY[/BBvideo]
Top Speed 174.2 MPH
