can someone steer me in the right direction as to which one of these taps i need to tap the "normal" full flow location, i believe it's 3/8 but they have several different types listed
https://www.fastenal.com/products/cutti ... 01:^3/8%22$|~
Sent from my iPod touch using Tapatalk
which 3/8 tap for full flow?
Re: which 3/8 tap for full flow?
Fastenal #55285
For threading light alloy you don't need to spend big bucks on a machinist-quality tap, just get something better than cheapo Chinese.
Do you have the ¼NPT tap for the oil pump passage? That'd be their #55284 or
Note that when plugging the pump's outlet you often will need to grind the tap shorter so it'll make threads of sufficient diameter before bottoming out against something...a similar problem may be encountered when tapping the case, if you force a bottomed tap it can crack the case - drill deeper and/or shorten the tap.
ridenrace6
ok thank you very much for the info, i was very confused when they listed 14 choices for a 3/8 pipe tap lolMarc wrote:Fastenal #55285
- sideshow
Also worth looking at; http://www.harborfreight.com/hand-tools ... 69877.html
It doesn't take much tap to make nice threads in your target material. Nor does one feel bad about shorting inexpensive taps.
ridenrace6
ok thanks i have harbor freight and fastenal stores along with a grainger store all in about a 30 minute drive so now i have an idea of what i needsideshow wrote:Also worth looking at; http://www.harborfreight.com/hand-tools ... 69877.html
