ChadH wrote:
A) What pedal lengths should I be looking for. I'm guessing as short as possible, since room is cramped, but I'm a little worried that with the rather upright seating position, my shins will be hitting the M/C assemblies. It's hard to know for sure, without having the assembly in-hand for trial fitting.
2) What diameter M/C's should I be looking for? I'll be running basic VW/Ghia calipers front and rear.
III) Most importantly, is it even worth the effort and expense. I'd like to be able to adjust brake bias, but maybe it's just one more thing that I'll need to sort out when I get the car running. Should I just get a stock type M/C and be done with it?
The ones used in buggies/sandrails are pretty short and should fit nicely, get plenty of measurements from them before you commit to buying.
IIRC I used 3/4" bores for the brake M/Cs and 5/8" for the clutch. The brake M/Cs were pushing fairly large Porsche calipers though. The stock bore IIRC is ~19mm so 3/4" is pretty close. Both Ol' and FJ bring up good points.
To what FJ was saying, I remember my gas pedal was sticking during an event. And NO, in case you all are wondering, the quickest way around an AutoX course is not with the gas pressed down all the way I found out the hard way.
So yes, mounting the pedal cluster with a few extra mm under it for something to not bind up the assembly is an excellent idea.
Ol'/Chad, maybe 1 brake assembly with a balance bar and 1 separate clutch pedal mounted to get the pedals where you want them respective to each other instead of 1 complete assembly??
