Weight difference
flyguyeddy
Weight difference
Is there a huge difference between the wasser case and a type 1? Im seeing 30 pounds mentioned but it cant possibly be THAT much
flyguyeddy
Re: Weight difference
I should specify, an oxy converted wasser case
- sideshow
No, but you have to be specific what you are comparing to. This bare case is 41.6 lbs
buildabiggerboxer
Mag is around 35% lighter than aluminium, so around 27lb for T1 case.
Consider adding the weight of a deep sump to the T1 case unless going dry sump.buildabiggerboxer wrote:Mag is around 35% lighter than aluminium, so around 27lb for T1 case.
The wasser will hold ~4.5L in the sump as-is.
