under deck lid turbo header
seabeebuggy
Post by seabeebuggy »
I have been gone for a long time . I have pulled my bug out of storage. I last drove it in 1989. the engine has sat all that time and Im not going to bother with it. I have my 2006 turbo engine in my buggy and will pull it out or do a subi swap? either way I want power. Back to my original question is there a factory made header for under deck lid use besides the hideaway?
GS guy
Re: under deck lid turbo header
Post by GS guy »
Kawell used to make a "street" under the lid draw-through exhaust. Not sure if they're still active in the VW world?
panel
Post by panel »
You mean besides the CB Hideaway? http://www.cbperformance.com/product-p/7301t.htm
I see lots of guys just use a regular header and then make an up pipe. Myself included have done this. Is it for FI or draw through ?
DRD......http://www.thesamba.com/vw/classifieds/ ... ?id=461512
Samba.........http://www.thesamba.com/vw/forum/viewto ... highlight=
Kit in a box........http://www.shoptalkforums.com/viewtopic.php?t=138515
MarioVelotta
Post by MarioVelotta »
I have a DRD version I might consider selling.
The Dub Shop
Mario@thedubshop.net
1600 ITB NA - 18sec
Facebook-Tech-Store
Chip Birks
Post by Chip Birks »
The DRD is an A1 header btw. I got mine directly from them. Very nice product.
seabeebuggy
I don't know that header. is it good for duel blow through under the deck lid ? or at leas a lid with a stand off?
seabeebuggy
Maybe i just need to drop in a 2332 with high compression. That should make the bug move.
Chip Birks
seabeebuggy wrote:I don't know that header. is it good for duel blow through under the deck lid ? or at leas a lid with a stand off?
It works great for blow through. Positions the turbo in pretty much the same spot as CBs hideaway does. All of the pipework goes to the front of the car though. The turbo looks like its just hanging onto nothing.
https://goo.gl/images/DJnPV7
seabeebuggy wrote:Maybe i just need to drop in a 2332 with high compression. That should make the bug move.
Yep, almost as good as a pump gas low boost turbo'd 1915 would :wink:
seabeebuggy
Well I am going to be pulling the buggy engine out for the first time in 10 years. I need to send the trans out for new gearing. I'm still on the fence on what to do with the engine. I have 2 cars and 1 engine.
petew
Post by petew »
I've got the CB hideaway. It get's the job done, but it's probably too big for my car. If you are 1915 or bigger, it's spot on. I will say though, I've had issues routing oil lines and the like. If the DRD takes the pipes forward, that will give you a LOT more room for things at the back as well as more ground clearance. That's one place where the hideaway really sucks.
seabeebuggy
I remember my CB hideaway header it was big, boost was slower with it. I have a 2006cc. When I went to a smaller header it was so much better. I'm still on the side of a big non turbo for my next build. Boost is so fun though.
petew
Post by petew »
Booooooooooosssst! C'mon, you know you wanna. ;)
