STEERING PROBLEM -- THINK STEERING BOX.
NextGen
Post by NextGen »
This has been going on for a while, but now is getting worse. My friend put the bug on his lift and checked the wheels, and wheel bearing, shocks entire from suspension and found the car safe to drive -- meaning nothing is going to fall off and I crash into a wall or go off a cliff. But weight of the bug was on the lift, wheels were not lifted.
. The problem the steering is rough, when driving straight if I move the wheel it will grab and stay in that position till I pull it back. Dangerous!!!! Mind of it's own.
So I did a simple test, Jacked the front end off the ground and turned the steering wheel it is rough throughout the range. Tried adjusting the steering wheel gap and yes that works but rough moment is throughout the range.
I am guessing the the Steering Box.
Next question. Can I remove it by just taking off the front wheels, without removing the gas tank.
Joe Cali
The Type IV Upright Conversion Manual
Beetle Magnetic Deflector Shield
http://www.nextgen-usa.com
Next Generation-U.S.A.
Email: nextgenusa@optonline.net
or
joe.nextgenusa@gmail.com
qaxa
Re: STEERING PROBLEM -- THINK STEERING BOX.
Post by qaxa »
Gas tank needs to be removed.
NextGen
Post by NextGen »
That I figured and the easiest way. So to you agree that it is most likely the Steering box?
Joe Cali
or
NextGen
Post by NextGen »
Funny about removing the tank, I thought so, but what through me off the Bentley book said you can do it by lifting the car and taking off just the drivers side wheel. Ha.
I guess you can but it would be like building battleship in wine bottle.
Joe Cali
or
qaxa
Post by qaxa »
Yes I should have elaborated on that: it is possible but not practical unless one has really, really small hands :)
Much easier to remove the tank and get some space.
Superbeetle with struts or standard with beam?
Yes its probably the steering box.....but...
In either car type it can also be ball joints and/or tie-rod ends rusted solid and gritty inside. On a super with struts it can be the idler arm bushing. Ray
NextGen
Post by NextGen »
Ray actually one ball joint's rubber is missing - Thanks, into checking mode again.
Oh it is a standard.
Joe Cali
or
NextGen
Post by NextGen »
Joe Cali
or
