Ever since I had rain go down the carbs to fill up the cylinders, the engine has never ran right. I did end up getting it going pretty well, but I didn't go great, and then I've somehow managed to spring quite a big oil leak, so I'm in the process of replacing the pistons, cylinders and rings, along with whatever else I come across.
A new 1916 cylinder kit is waiting to be installed, and I've pulled the motor and finally got the gland nut off; that was quite a mission!!!
End float will be checked, but I'm hopeful it will be fine as I can't notice any movement. I was going to use Teflon buttons instead of the circlips, but have decided to not go that way, unless someone can convince me otherwise.
I plan to just pull the old top end off, and replace it. The bottom end should be good, there was never any knocking or any other signs of issues, and the previous rebuild was done by a very reputable guy here in Australia and all top quality parts form the bottom end.
I'm hoping others here can make suggestions as to what I should look out for....
I also have a couple specific questions:
While I'm at it, should I replace the oil relief valves? Should I take off the oil pump cover and give it a good clean? Currently this sends oil to an external oil filter. When I eventually remove and replace the oil cooler seals, what is a good way to ensure the cooler is flushed clean?
I think that's it for questions right now
Thanks in advance!
Sent from my Pixel XL using Tapatalk
that's not the book I downloaded... I will see if I can get it from somewhere.
