Oxy crankcase ventilation
- grelland
Guys,
Looking for some advice on crankcase ventilation.
For the last couple of seasons, I have run a very simple setup with a Berg breather box and a AN-10 hose to an adapter in the distributor hole in order to balance the left and right side case halves: I am planning a change in the air filter setup, so I will not be able to fit the Berg tower any more.
So to the question:
Is this left-right case half hose really necessary? Can I get away with using a simple oil filler like this: And then a breather box/catch tank on the firewall?
Are there any other considerations with an oxy case vs standard type1?
So to the question:
bug66
Re: Oxy crankcase ventilation
Put that filler tube in a lathe. Turn it down to 40mm, use 40mm hose to a custom breather box with a 40mm airfilter from Biltema..
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
flat4olsen
My engine is pretty much identical to yours. I vent from the valve covers and from the oil filler (I run an OEM Mexican generator pedestal) to a breather box on the firewall. No problem with excessive pressure or oil leaks. I think you will be fine with the oil filler shown above.
Don´t throw your Berg breather away. Just send it to me, and let me throw it away for you
- grelland
Hehe. Thanks guys. No need to overcomplicate then
Just for curiosity, flat4Olsen. Is it necessary to vent the valve covers? I have not done that on any of my last builds.
flat4olsen
I honestly don’t know. Some say yes and some say no. It can’t hurt, so I just did it to be safe.
Do you want my address so you can send the Berg Breather?
bug66
The logic of not breathing the valve covers are that the oil shall go down the 4 push rod tubes. Not the ventilation.
That little breather nipple is no way near enough. A stock 1600cc Type 1 engine has a lot more ventilation..
bug66
And it does not matter if the breather box on the firewall is large, if the bottleneck is at the engine side..
flat4olsen
I am not going to argue about the logic of breathing the heads. As I said, I don’t know if it is needed. I know Porsche did it on the 914 with 2.0 l engine, and I think they did it for a reason. If it works for Porsche I have no reason to question the funktionallity.
bug66
Did Porsche vent both sides, or just one side?
One side fills up with oil, the other doesn't..
flat4olsen
