I haven't been online for a while. To those who I have made friends with and I haven't replied to emails, please forgive me. I haven't been well for a long time, but I'm starting to feel better.
My problem.... A couple days ago I went and started the car, but it felt like it was only running on 3 cylinders and when I revved it, it would backfire. I've always had a problem with the Weber on the right, so I thought that this was my chance to put on the other set that I have which are much better, so all good.
I had to pinch a couple parts from the Weber's which were on the car, and found that the person I paid to rebuild them installed the accelerator pump diaphragm on backwards! Anyways, I'm ready to install the better set, and thought I would do a compression test. The results: 1:130, 2:133, 3:153, 4:145. Obviously something is going on with the left side, so I'm about to check the clearance on the valves, and retest. Those tests are with the engine cold, and wide open accelerator obviously because I haven't installed the carbs yet. The picture that is attached are the plugs, one being on the left and 4 on the right. To me they don't look too bad, I was expecting one and two to look lean.
Some background.... The top end was rebuilt not long ago. I had the heads checked over by a VW specialist who installed new exhaust valves while he was at it. The carbs I've pulled off were twin IDF 40mm Weber's which will be replaced with twin 44mm Weber's.
The engine has for the most part ran cool all the time. I have noticed that the temps go up with I'm cruising at between 115-120 km/hr with the sump oil temp going up about 20-30 degrees Celsius. As soon as I drop the speed, so do the temps. BTW, the motor is 1916.
What do you all think? I'm kind of hoping that the valves on the right are a little tight, and that the compression will go up a bit when I regap them, but I am a little worried that they won't. After I do that I'll put some oil in the cylinders and see what the compression is then.
Everyone please cross your fingers!
Sent from my SM-N950F using Tapatalk
