Haltech ELITE
porkchop-rob
Haltech ELITE
I am in the process of building a Turbo Stroker engine that will be managed by a Haltech Elite 1500. I am hoping to chronicle the Haltech/EFI portion of this build and maybe help someone else who endeavors to go EFI. I know 0% about what I am getting into, but I have a good friend who is running Haltech on his bug and a professional tuner close and available who is Haltech and VW knowledgeable.
FIrst, the parts list:
Haltech Elite 1500
Haltech Premium Wiring Harness w/ fuse and relay box
Haltech Flex-Fuel Sensor
CB Performance TPS
CB Performance Fuel Pressure Sensor
CB Performance Micro Cam Sync
TheDubShop Crank Trigger Package
TheDubShop LS2 coils
TheDubShop IAT Sensor
VDO Oil Pressure Sensor
VDO Oil Temperature Sensor
Bosch Knock Sensor
PLX EGT (for CHT)
PLX Wideband O2
DIYAutoTune Boost Control Solenoid
AND....what seems like a never ending list of matching connectors!
PRO TIP #1 - Don't forget to budget for and order the connectors that match your sensors and outputs.
I will update this thread as I gather more information and/or parts as well as when I inevitably run into a question, issue, or realization that may help someone else.
Thanks!
Haltech Elite 1500
CB Performance TPS
Bosch Knock Sensor
PLX EGT (for CHT)
PLX Wideband O2
Thanks!
Re: Haltech ELITE
Subscribed. I ran two different older haltech systems on my bug in the past.
Steve
My Baja Build
My Baja Build
porkchop-rob
Re: Haltech ELITE
LINKS to the junk I am using...
Haltech Elite 1500 & Premium Wiring Harness w/ fuse and relay box
https://www.haltech.com/product/ht-150904-elite-1500/
https://www.haltech.com/product/ht-0110 ... on-sensor/
CB Performance TPS
http://www.cbperformance.com/product-p/7159.htm
http://www.cbperformance.com/product-p/7163.htm
http://www.cbperformance.com/product-p/7073.htm
http://thedubshop.com/crank-trigger-pac ... type-1-vw/
http://thedubshop.com/ls2-dual-coil-package/
http://thedubshop.com/intake-air-temp-sensor/
https://www.cbperformance.com/product-p/2350.htm
http://vwparts.aircooled.net/VDO-300F-O ... 323057.htm
Bosch Knock Sensor
PLX EGT (for CHT)
https://www.plxdevices.com/EGT-Exhaust- ... 002184.htm
PLX Wideband O2
https://www.plxdevices.com/Wideband-O2- ... 002719.htm
https://www.diyautotune.com/product/ebc ... enoid-kit/
CB Performance TPS
Bosch Knock Sensor
PLX EGT (for CHT)
PLX Wideband O2
Mathias
Re: Haltech ELITE
Take a look at the dub shops cam trigger setup, it's awesome. build quality is perfect.
- Paul H
Re: Haltech ELITE
Are you really going to splash out $1800 for an ECU ?
porkchop-rob
Re: Haltech ELITE
Already purchased.
I am paying for what I know works and what my tuner is comfortable with. This may not be the correct path for everyone, but it is the decision we’ve made. I have zero interest in “tinkering” with the tuning. The car will make good power with the combo chosen and will be tuned for excellent driveability. I am more interested in driveability and “set it and forget it” tuning ability than I am with all out HP.
- woodsbuggy1
Re: Haltech ELITE
The last set of DRD heads that I bought from Darren were lacking in quality, hope you have yours rebuilt to correct specs and better quality valves and guides than DRD used.
type1.racer
Re: Haltech ELITE
Can't wait to see how this progresses. I've also thought about taking the EFI route but have yet to pull the trigger.
SuperRSi
Re: Haltech ELITE
So how did this go? I am thinking about going with the Haltech 1500 on a turbo 2.6L T4.
nic
Re: Haltech ELITE
loving my elite 1000 on my bus way better options than the CB quicktune i had before.
