Tail light grommet
turboedbug
Tail light grommet
Post by turboedbug »
I am having a hard time finding the grommets that protect the wiring that go through the rear fender holes. Any help would be appreciated.
Heres a photo of what i am working with.
Thanks againImageImage
Sent from my SM-N960U using Tapatalk
Turbo!
H2OSB
Re: Tail light grommet
Post by H2OSB »
Try West Coast Metric
H2OSB
turboedbug
I have cruised through west coast metrics site and cant find anything that looks like it will work. Guess its time for an email
Turbo!
H2OSB
Post by H2OSB »
Well, I won't lie, I'm a bit confused by the oblong hole. My cars are 73 and 74 and all the holes are round, so I apologize if I steered the wrong way. WCM usually has everything.
H2OSB
SCOTTRODS
Post by SCOTTRODS »
So... the light seals only exist in the lens to housing if I remember right... the fender to housing is not "sealed" so much as a rubber gasket is there to prevent paint wear. the way the housing and light and lens assemble, is supposed to "seal" the lights from water intrusion.
Your picture shows some great wire protection in place already. However, A round Grommet will fit nicely in the Oval/oblong hole as well. If I remember right, I saw a variety pack of grommets at the Harbor freight store for a little bit of nothing... That might do what you want. Since all you mention is wire protection, this should help to some extent.The sizes went up to 1" if I remember, so these may still be a little small. but the concept and direction is the same if you shop Home Depot or Car Quest or NAPA or some other sources.
TB, typically what Scottrods said is pretty true. A hole like that probably is for a light with a bulbus protrusion that intrudes/fits into the slotted hole with the gasket having the piercings for the other holes to hold light housing in place. Grommets typically are of thicker material so if the tail light housing were a flat surface there would/could be pushed up.
Kafer_Mike
Post by Kafer_Mike »
H2OSB wrote: Sat Nov 10, 2018 8:27 am Well, I won't lie, I'm a bit confused by the oblong hole. My cars are 73 and 74 and all the holes are round, so I apologize if I steered the wrong way. WCM usually has everything.
H2OSB
It appear to me that someone opened up the round hole and added a couple more. Here's the standard seal --
Kafer_Mike wrote: Mon Nov 26, 2018 9:26 am
H2OSB
I agree HDOSB: If you go back and look at the hole you will notice that the straight cuts enjoining the two arcs are not in perfect sync at the ends of the arcs like a manufacturer would make but slightly "bulge'd" in. The edges are rough also.
It would be interesting to know what was put there asuch as if the hole was for a deep penetration by the different than stock housing or something like that.
SCOTTRODS
Post by SCOTTRODS »
Probably someone installed some other tail lights... square or something... and to make the holes work they just augered them out with whatever... I know what the seals look like, but hadn't had a rear fender off in a long time... I need to on one of my vehicles... but haven't due to health issues and energy levels...
Sorry to hear of the health and energy issues. Keep the build and other positive thoughts in your mind as it can take away some of the concentration on the other two issues. From experience 8) !
