Hi,
I 'm building a Type 4 engine to go in a Bug which obviously has a Type 1 bug transmission in it.
I realise i need to get a conversion flywheel which has a pilot bearing pressed into the centre, but do i need to remove the pilot bearing out of the end of the Type 4 crankshaft?
Thanks, Mike
Pilot Bearing in Crankshaft on Upright Conversion
topnotch
- sideshow
Re: Pilot Bearing in Crankshaft on Upright Conversion
Yes, it will occupy the same air space so must be removed.
Try;
Drawing a crank assembly https://www.shoptalkforums.com/viewtopi ... 1&t=113139 for removal tips
Try;
topnotch
Nice one - thanks - i managed to remove it using a 10mm socket and some plasticine
