2165 high compression build
RLFD213
Post by RLFD213 »
Hi everyone
I am getting to the point where I’m going to order what I need to start my engine build. This is my thought and I’m looking for any tips or insight. Thanks
2165 high compression E85 motor
New aluminum case from 2 brothers
4340 78mm crank
H beam rods 5.5
94 mm b pistons
Straight cut gears
26mm oil pump
Not sure on cam, Rod, crank or cam bearings, rocket arms, carbs or injection.
I was looking at 2nrothers website and may try and order as much as I can from them. They’re reputable and can do the machine work and balance work all there.
Chip Birks
Re: 2165 high compression build
Post by Chip Birks »
Sounds fun! What are you thinking for heads? Street or strip?
RLFD213
Post by RLFD213 »
I was gonna talk to brothers and see what their opinion is. Probably D ports and 44 intakes 37 exhaust. There is a lot that goes into them as you know and I want to see what their thoughts are. It’s gonna be a street car but I live close enough to the track I can run it on amateur nights.
bug66
Post by bug66 »
Why 2165?
It will actually be easier to build a bigger engine.
78mm crank and B pistons will need shorter cylinders.
I would do a 82/84mm crank and as big of a cam and heads as possible.
FK89 and 48/40 Comp Eliminators.
With a good port job, 250hp is pretty easy. You can go 13-13,5-1 on E85
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
