Turbo problem
Amurray
Turbo problem
Post by Amurray »
Well I drop my engine today to inspect my turbo due to the sound it was making. Wasn't sure what the heck happened...well now I know the blades rubbed the housing on both sides...a 600hp capable turbo is now crap. Damn Damn Damn DAMN. That really hurts.......... HAPPY NEW YEAR TO ME :( .... Anyone want a used door stop😞.
Oh well poop happens....this is just forcing me to buy a new GTX35R turbo capable of 750HP.
Don't know how to break this to the wife but hey my birthday is in a few days maybe just maybe I can talk her into it getting it :D
buguy
Re: Turbo problem
Post by buguy »
Bummer. No clue what could have happened?
Amurray
Re: Turbo problem
Post by Amurray »
buguy wrote: ↑Wed Jan 02, 2019 6:35 pm Bummer. No clue what could have happened?
Nope....I rapped the exhaust and changed to Brad Penn 20-50 oil. The green oil. It was fine before that. Well I took the Brand Penn out of the engine. I spoke to a few VW people that advised against using that oil in an turbo air cooled VW. I have 6.5 quarts left that I will NEVER use.
buguy
Re: Turbo problem
Post by buguy »
Weird. I wouldn't think that oil would cause your bearings to take a crap. Even if it's not good for aircooled vw, it's surely fine for a turbo.
Is there any weird side load on your turbo causing stress on anything?
Clonebug
Re: Turbo problem
Post by Clonebug »
I've been using Brad Penn Green for 4-5 years and all the miles on my Turbo engine have had this oil in it.
I've used 10-30, 10-40, 15-40 and 20-50. No issues with my turbo.
Amurray
Re: Turbo problem
Post by Amurray »
Then I really do not know how it happened. I made two changes to my car and it's been working well up untill that point oh well like I said πŸ’© happensπŸ€·πŸ½β€β™‚οΈ. I known wrapping the exhaust didn't do it.
buguy
Re: Turbo problem
Post by buguy »
Yeah but yikes. If it were me I'd like to know what happened before I out another $1000 turbo on it!
Amurray
Re: Turbo problem
Post by Amurray »
buguy wrote: ↑Wed Jan 02, 2019 8:21 pm Yeah but yikes. If it were me I'd like to know what happened before I out another $1000 turbo on it!
I know but theres not much to the turbo. It gets oil and worked fine up untill this point. Boost comes on quick. It still makes boost even in this state but the shaft is definitely moving to hit the housing but none of the blades are broken. The last drive I hit 15psi and all hell broke loose but when l got home I noticed the sound. The temps exiting the turbo are hotter by about 30Β°. The temp are usually around 124Β° exiting the turbo. The intercooler brings it down to around 88Β° and lower if I'm driving. I took the Brad Penn out and it sounded a little better but the damage is done. I'm sending it out for inspection.
ToRy 70
Re: Turbo problem
Post by ToRy 70 »
Clonebug wrote: ↑Wed Jan 02, 2019 7:45 pm I've been using Brad Penn Green for 4-5 years and all the miles on my Turbo engine have had this oil in it.
Been out of the game for a bit. Is Brad Penn still the go-to? I have enough for one more change. I'm not even sure if they sell it anymore, unless it's changed names.
Chip Birks
Re: Turbo problem
Post by Chip Birks »
I just use mobile 1 0-40. Good enough for me.
madmike
Re: Turbo problem
Post by madmike »
It's called Penn Grade now ,, I'm still using it without issues :wink:
Just maybe the thing got too hot after the wrap??? :roll: I'm just guessing :(
woodsbuggy1
Re: Turbo problem
Post by woodsbuggy1 »
Brad Penn is the oil of choice in aircooled VW engines especially racing/ hard use applications, have seen much longer bearing life and cam wear issues have vanished also. One thing that I have learned from the diesel guys is to always let a turbo engine idle for several minutes prior to shutdown so EGT's reach a low enough temp that the turbo gets proper lube. My Dodge Cummins never get shut off before the EGT is below 300F. Hope you get your problem figured out.
66brm
Re: Turbo problem
Post by 66brm »
The reason for idling down a turbo engine is that they can spin up to 45000rpm and they can have some inertia that takes a while to slow down. If you shut your engine down straight away with the turbo still spinning at those speeds it's not getting any oil supply and can lead to early bearing failure.
madmike
Re: Turbo problem
Post by madmike »
Just out of curiosity? what brand turbo is it?
66brm
Re: Turbo problem
Post by 66brm »
madmike wrote: ↑Fri Jan 04, 2019 4:29 am Just out of curiosity? what brand turbo is it?
Gt35r
