1600 single port
mini t
1600 single port
Post by mini t »
i have a 1600 sp with duel cannons and have a set of 34 icts that i'm planning on installing is there anything else i should do , i'm also thinking of doing a mini stroker 1800 later i have a H case is this case a good platform for that
woodsbuggy1
Re: 1600 single port
Post by woodsbuggy1 »
You would probaqbly want to consider a dual relief case for any type of performance application, many people have reported problems with the H cases cracking. Also a 4 into 1 merged header is a much better choice for performance.
Good Luck
Kenric
sideshow
Post by sideshow »
It was mediocre in its day, now downgraded to "cottage-cheese alloy."
While an OEM case, the smart money moves to the still available OEM cases that have loads of upgrades/corrections. You will have to update the oil system/head studs/oil pump (all changes for the better).
