Show of hands- who runs without axle circlips?
STOICH
I have heard over the years that the IRS axle circlips can be removed for a number of reasons. In my case, I had to grind off the ends of my axles as they were mushroomed preventing CV removal, and in the process, I sanded off the circlip grooves so the clips will not go back on. Is there anybody here that has experience in ditching the clips?
- BajaBug222
Re: Show of hands- who runs without axle circlips?
I run both ways. On the pre runner only have them on the trans side. On the 5 car I’m running both sides
I run them. A good safety device for a just-in-case awkward loading.
STOICH
This was exactly my plan. Supposing the limit straps are right, no issues then with this for you?BajaBug222 wrote: ↑Fri Jan 18, 2019 8:28 am I run both ways. On the pre runner only have them on the trans side. On the 5 car I’m running both sides
Lee- I would much rather have them for sure, I guess my question was is this axle junk, or is there some life left- I'll give it a whirl I suppose. Thanks for the help!
I lost my contact lens so I am basically blind right now. From what little I can read my point would be that the axle can slide around with no C--clips and potential could slide out of one or both CV joints could slide out of jam on extreme suspension travel. I know guys who don't use them and have had no problems but then there is the opposite.
Contrary to thought, engineers don't add things unless they are proven to be good/useful.
- CentralWAbaja
Then there is this option.
Keep the clips shorten the axle a little so that it is not beating itself to death on the flanges in the mid stroke and still be able to droop just as far before binding.
STOICH
Now that's pretty snappy!CentralWAbaja wrote: ↑Sat Jan 19, 2019 11:40 am Then there is this option.
- BajaBug222
Not a bad idea. I’m running limiting straps. Next time I order axles I’ll go a different route. Not in a hurry to special order another set.
- CentralWAbaja
You can order CV's from Kartek now with this counter bore already done in the star. They have about 4 options if I remember right as to depth.
STOICH
Do they go down any further before binding if you don't shorten the axles?CentralWAbaja wrote: ↑Sat Jan 19, 2019 11:40 am Then there is this option.
- CentralWAbaja
If I understand your question? Yes this process will allow for extra droop. Which is why I did it. I was having to shorten the axles more then I originally thought to clear at the mid point so I opted to bore the stars to get that extra range back with the shorter axles.STOICH wrote: ↑Mon Jan 21, 2019 6:32 pmDo they go down any further before binding if you don't shorten the axles?CentralWAbaja wrote: ↑Sat Jan 19, 2019 11:40 am Then there is this option.
STOICH
Any guess how deep that cut is?CentralWAbaja wrote: ↑Sat Jan 19, 2019 11:40 am Then there is this option.
- CentralWAbaja
I could guess....or I could tell you exactlySTOICH wrote: ↑Fri May 03, 2019 2:09 pmAny guess how deep that cut is?CentralWAbaja wrote: ↑Sat Jan 19, 2019 11:40 am Then there is this option.
- CentralWAbaja
Mine are done at .188 but you can go up to .25
