Cylinder Base Gaskets
David Follett
Post by David Follett »
Finally after not being able to work on the converted Type 4 engine for many months I have parts for reassembly and hope to get the Ghia back on the road. Do I have to use a cylinder base gasket? The old cylinders did have what seems to be a shim and not a gasket. I will not be using a top gasket.
VWDAVE
greggholmes
Re: Cylinder Base Gaskets
Post by greggholmes »
no gasket
read and see video below, note at 1:24:25 in the last video below for the gasket then note at 1:00 for their resume dyno run
https://documentcloud.adobe.com/link/tr ... b8b936bc75
https://documentcloud.adobe.com/link/tr ... b7711a9c57
https://youtu.be/TpoFSHQCRW8
note at 1:24:25 in the last video below then note 1:00 dyno run
https://youtu.be/Ce3w5vsNRYg
As noted...no...you do not need a base gasket but you will have to seal this area to not have oil leaks. To remove the top head gasket you need to lap the cylinders lightly on glass...then lap them lightly to each head opening. Ray
