Oil pump selection
lil_azza
Oil pump selection
Post by lil_azza »
1600/1641
Deep sump
Bugpack 4062 3 bolt
Twin 34s
Dog house
Ar case
In a convertible beetle
What size oil pump do i need
21 or the hd 26-30 pumps?
sideshow
Re: Oil pump selection
Post by sideshow »
Standard pump 21mm, standard plungers, standard springs.
If the case is so worn out an oversized pump might help, replace the case.
Bruce2
Post by Bruce2 »
The standard pump for a dual relief 1600 case is 26mm. That's what you need.
