Bugpack 4062 1600 solex 34pict3 wont idle
lil_azza
Is running a 009 iv swapped the electronic out for points
Stripped and checked the carb multiple times and tried another
Timed at full advance 30deg
Will idle if warm if choke is engaged
Revs lovely no lumps
What the hell am i doing wrong:/ i can pull a vacuum dizzy off my other car if u think its that?
Helppp
Helppp
- V8Nate
Re: Bugpack 4062 1600 solex 34pict3 wont idle
Do you have the throttle plate adjusted correctly then adjust your two screws on the drivers side of the carb?
lil_azza
Yes mate adjusted them
The screws only make a difference if the revs are high or if the choke is on
lil_azza
Checked for leaks nothing
- V8Nate
The only thing I could think of if that is set would be a clogged idle jet or a bad fuel shut off solenoid
- V8Nate
That carb should have the throttle plate barely cracked open and the idle speed should be set with the big screw on the side. Then the small screw leans or richens the idle. If the throttle plate is open too far you will expose some of the progression ports and it will be a bitch to tune
lil_azza
Do what ur saying is it should be cold with the choke plate shut to tune idle?
- V8Nate
The engine should be warm to tune the idle. The small screw on the throttle arm should be backed all the way out then turned in till it barely touches the choke cam(with the choke open) open up the big screw(idle air bypass) so it runs at a pretty high idle then screw it in to lower the idle(you will probably have to mess with the idle mixture screw to get it to run smooth enough to keep dropping your idle)
lil_azza
Oh right yes thats how I usually set them
This one will just not play ball it wont respond to the big screw unless the choke is set
Iv even swapped jets about to how it says onliiy should have
- V8Nate
Sounds frustrating it's got to be something in the idle circuit
lil_azza
Surely not 2 carbs tho?
- V8Nate
That would be a uncommon occurrence. Is there any part that is shared between both carbs? Hows your fuel pressure
lil_azza
Yea i guess it could be
I presume its ok the float bowl is always full
I can try another pump
lil_azza
But no completely different carbs
lil_azza
Il have to check the valves
Could it be a few tight valves not opening properly and due to the higher lift cam ?
