I’m running a Cali conversion in my early busamd I took a lot of time fitting the type 4 into the type 1 shroud. My initial thinking was that a bigger cooler must be needed.
Thinking more, is it possible that the type 1 cooler is more efficient because the air speed will be quicker due to a smaller chamber around the cooler than the type 4 with type 1 shroud.
Anyone have any data or info either way?
Cali conversion oil cooler
patto
Re: Cali conversion oil cooler
Surprised Next Gen hasnt popped up here as he has said the type1 cooler is more then enough on a type4 conversion! Wreck also seems to have good information based on his use in hot climates. Hopefully one of them chime in?
wreck
I haven't any first hand experience with stock oil coolers in a doghouse set up . I would've thought the bigger type4 cooler would cool better, what the airflow difference through the coolers would be I don't know . There are a lot of different things that contribute to oil temp . A bus will always require more cooling than a bug because of the extra power levels required to push it along at the same speed .
H2OSB
As soon as he sees this he'll chime in, but he's said it many times, and even to me personally. The T1 oil cooler cools more than enough for a T4 in an upright configuration, per Joe Cali.
H2OSB
H2OSB
cal 67
The T4 cooler in the T1 shroud will net about the same temperatures as a T1 cooler because the duct and possibly the fan can only flow enough for the smaller T1 chamber. So do whichever you want. Or pop off the duct, space it out 1/2-3/4” and tack it all back together. Then enlarge the duct entrance next to the fan. Then it might flow more.
bushoarder
All good feedback, thanks.
I enlarged the shroud between the fan and cooler, but I think you’re right 67.
The fan is the same and at a given speed wont flow anymore. My thinking was that as the flow exits the fan it will expand more since I enlarged the volume and thus the speed will drop making the cooling efficiency of the type 4 not as good as you’d think.
Does that logic seem sensible? I’ve seen a few people say a t1 cooler works fine - perhaps the cooler / shroud are the things to keep constant and just sticking bigger coolers in doesn’t work. Putting an external cooler (as I have done) is the solution to get increased cooling capacity if needed. I’ve only done that as we cruise around on motorways a fair bit and it keeps temps in the fully laden bus at c 100c.
Other options are to do stock type 4 cooling or go back to a t1 cooler in a proper stock fanhousing and not the aftermarket 30 horse types.
NextGen
Guys sorry it took so long to get back to you guys I was out of the country for a while on my 50th anniversary. Was in Barcelona, Spain.
A lot of my saying a T-4 cooler is was do to many other guys testing the T-4 cooler in not only T-4 cars but also T-1 cars. Not many more rows of of oil cooling tubes on a T-4 cooler to make much of a difference. Also because I assumed due to the larger engine being cooled by a T-1 fan housing I thought the engine would overhead. BIG WRONG!!! In a bug the T-4 is hardly working. I had problem reaching 170 f oil temp. A 90c Thermostat took care of that. The warmest I get on a 90f day doing 70 mph for hours is 210 max. And that without some missing sealing rubber on both sides of my duel Dells.
So I sold over $600 of oil cooler and braided hose and sandwich adapt or at a swap meet. T-1 and T-4 cooler seem to make little difference in a Cali Style Upright conversion.
That said like any thing else. Over sized engines need more cooling. The Bug I am running now has 120 hp and is fine. Guys in Europe run 160 hp with a Cali Style, No problem. I heard larger but cannot verify. .
Buses are different they need all the help they can get. I would think if you are having issues with the stock coolers, and you have my manual or not, just screw on a Sandwich plate adapter with a 170f thermo built in and run and extra cooler.
Joe Cali
The Type IV Upright Conversion Manual
Beetle Magnetic Deflector Shield
http://www.nextgen-usa.com
Next Generation-U.S.A.
Email: nextgenusa@optonline.net
or
joe.nextgenusa@gmail.com
or
bushoarder
Thanks joe, this engine was built for my 03 German looker originally and has ended up in the bus!
We got 83hp from an 1800 with 40 idfs and a 4-1 exhaust!
I’ve done as you said joe and spin on sandwich plate with thermostat in.
Nice short oil hoses and it seems to be working ok.
NextGen
Nice work, all you can do except, to put the bus on a diet, ha. Just don't over load it.
Joe Cali
or
or
