Ok guys,
I am now starting my build using a CB hideaway header. I am looking for opinions as to if or not this header is going to work on my Draw Thru plans.
Is a full body with lid 67 Beetle.
CB Hideaway 1.5" header with 2" pipe X 12 - 14" extension to the T3 turbo, a Holley 600 feeding into the turbo.
2110 stroker with Ponchito heads, 1.25 rockers, CB 2246 cam, straight cut gears, full flow, 8.3-1 cr.
As always, opinions are appreciated..
Mark
Draw thru using a CB Hideaway header?
Blownbug
- buguy
Re: Draw thru using a CB Hideaway header?
Of course it will work! Really any header can be made to work. Just have to make the appropriate up pipe.
- Dan Dryden
It won’t work very well.
The air/fuel mix will need to travel uphill from the turbo compressor to the inlet valves.
You’ll probably find that it’ll be a pig to tune because all of the low air speeds during cruise will mean lots of fuel puddling....
for draw thru, you really need to mount the turbo higher than the inlet valves.
Blownbug
Dan,
The way I plan to set it up is using a 12" to 14" extension from the turbo header (UP) to the Turbo in which will be sitting right above the Alternator on the left side.. The Holley will feed right into the side of the Turbo and blow DOWN into the intake pipe to the heads.
- Dan Dryden
Ahhhh! Ok. That should work.Blownbug wrote: ↑Sat Aug 03, 2019 2:15 pm Dan,
- WickedWagens
Like this?
No reason it wouldnt work.
1968 Karmann Ghia land speed
G/CFALT 106.643 MPH G/CGALT 113.131 MPH
G/CBGALT 169.462 MPH G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH H/CBGC 94.334 MPH
H/CPRO 93.383 MPH H/CBFALT 101.282 MPH
H/CBGALT 120.591 MPH
Top Speed 174.2 MPH
Top Speed 174.2 MPH
