Good Morning or whatever time of day it may be when/where you are reading this.
I've recently picked up a type 4 case and a single head from a local VW guy that was closing down shop, and it has me interested in coming over to the dark side with my square back. It currently has a 1956cc type 1 with megasquirt EFI, but it's high compression and has some oil leaks and blowby issues that could be eliminated with a factory stock 2.0l I would think. I could re-build it with bigger chambers and get new rings to get them seated but if I'm going to all that work why not do it right??
Anyways my biggest question for a mild stock-ish 2.0l TIV would be what specific bits do I need? (I'd like to do this in the style of clatters sweep the floor build, good stock parts on the cheap.) I have an EB case with the oil fill open so it should be a '73 1.7 411/412 case. According to what I've read that should be better than a case out of a bus.
I'm also hoping to pick up some bits and pieces this weekend at bug-o-rama. I think either type 4 tins or 914 tins are good, and combine that with bus heat exchangers, and a Vanagon mounting bar are the way to go? Then for internals a 71 stroke crank, and some stock P&C's if I can find some in good shape, 1.7 heads or try to find some 914 2.0s that aren't cracked?
I'd like to then convert the stock FI runners and TB to run with the MS EFI I have to keep it looking stock but also be able to run a bit perkier of a cam, probably the CB street power cam.
This will be a long term project as the square is currently on daily driver duty while I rebuild my Honda engine
I appreciate any input I get here, and will continue my research and reading of what those who've done this before have done. Unfortunately a lot of old photos on this site are lost but still lots of good info.
--Reference List--
(Ongoing, please PM or post on the thread if you have some useful tips or photos that should be shared here.)
viewtopic.php?f=1&t=116220&hilit=conversion (Old conversion thread missing some photos)
https://www.thesamba.com/vw/forum/viewt ... p?t=581759 (Black Fastback thread from Clatter)
http://pws.cablespeed.com/~danielzink/notchback.htm (Daniel's Notch photos)
https://www.thesamba.com/vw/forum/viewt ... tf#7106953 (Specific T3 Boot photos from Clatter)
https://www.thesamba.com/vw/forum/viewt ... sc&start=0 (Thread with some good photos in it)
https://www.thesamba.com/vw/forum/viewt ... highlight= (More helpful photos)
https://www.thesamba.com/vw/forum/viewt ... 40#9353440 (Carb Manifold Mod)
https://www.thesamba.com/vw/forum/viewt ... ns&start=0 (Another reference thread)
viewtopic.php?f=1&t=145853 (Cheap Junk Rebuild Thread)
viewtopic.php?f=34&t=151136 (1.7 Rebuild Thread)
https://www.thesamba.com/vw/forum/viewt ... p?t=596485 (Notch with IRS conversion and T4 swap.)
-Individual Photos-
https://www.thesamba.com/vw/gallery/pix/2048486.png (Nate's mythical t3 bellows adapter template)
https://www.thesamba.com/vw/gallery/pix/1648951.jpg (Bobnotch photos)
https://www.thesamba.com/vw/gallery/pix/1489634.jpg
https://www.thesamba.com/vw/gallery/pix/1489631.jpg
https://www.thesamba.com/vw/gallery/pix/1489632.jpg
