New member
bauerl
New member
Hello, I'm new 1973 bus owner. Its a restoration project. Right now I'm trying to figure out what is wrong with #4 cyl. compression test. Dry test 1st 140, 2nd 130, 3rd 135, 4th 105. Wet test every cyl. comes up approx. 5lbs.
- V8Nate
Re: New member
Make sure valves are adjusted properly
bauerl
Re: New member
Valves are adjusted to .006 on both intake and exhaust. I will repeat to the test after I can run it for ten minutes or so.
Bruce.m
Re: New member
Blow compressor into spark plug with the valves shut and listen for a hiss from inlet / exhaust/ case breather, to find out where the losses are coming from.
