Not building boost
Booky
Not building boost
Post by Booky »
Have GT15 on a 1600 cc can not get above 2lbs of boost could the turbo be to small.
Schweg
Re: Not building boost
Post by Schweg »
Doesn’t sound like it just googling that turbo. Draw through? Blow through? EFI? What’s the set up?
When are you seeing the 2psi?
Booky
Post by Booky »
Blow through seeing boosts about 2300 rpms and I’m blowing through Kadrons.
panel
Post by panel »
What kind of wastegate on your project ? Internal or external ? Are you running any kind of boost controller ?
Don't hold back on the info/specs etc :D
Booky
Post by Booky »
Internally waste gate no boost controller turbo came off a Hunday sports car they were I think up to 1.8.I have been all over every connection to make sure it’s not leaking.
Schweg
Post by Schweg »
Where are you pulling your boost gauge reading from?
Is your fuel pressure regulator boost referenced?
What are you using to time ignition?
Have you checked header flanges? I had one that had rattled the nuts off and I was barely making boost. Also the above questions.
Booky
Post by Booky »
Boost reference for gage and fuel pump are coming from the port on the turbo. I have a cb Performance digital distributor for right now using there 7# boost program. Yes have looked at all connections 2 or 3 times and had someone else check them to.
Booky
Post by Booky »
I’m using cb performance graphite gaskets on all the exhaust joints but I will double check tomorrow.
Schweg
Post by Schweg »
Have you changed the jetting in your carbs? Are you Monitering AFR?
Booky
Post by Booky »
Yes to both afr at boost and wide open running around 12.1 to 13.5. running 55 on idle jet 130 on main jet and I boost referenced the float bowl.
Schweg
Post by Schweg »
How old are the pistons and cylinders? Ring blow by? Have you run a compression or a bleed down?
This is not a great plan but.... you could try running it with the waste gate disconnected. Being very gentle to not push yourself out of a safe AFR. At least then you can verify if the waste gate is set correct or not.
It sounds like you have everything else and have checked all items. An engine photo or two may help if something is plumbed incorrectly.
Booky
Post by Booky »
I did a compression test 120 all the way around did not do leak down test. I have not tested the waste gate yet I will do that tomorrow.
buguy
Post by buguy »
With that little turbo you should be getting plenty of boost. I'd guess the waste gate is bleeding off pressure or you have a header leaking. Can you spin your turbo with your finger?
Booky
Post by Booky »
Yes very easy to spin.With the questions that were being asked I am wondering if my waste gate might be bad and opening up under low boost like has been suggested.
bug66
Post by bug66 »
Are you actually driving it, or just free revving it in neutral?
Use a highly flammable spray to find the vacuum leak if there is any. Something is wrong :)
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
