So, my van is coming along nicely. Has a 3.2 1985 911 flat six, 915 gearbox, air ride etc.
Trying to figure what drive shafts will work. I think the 915 transmission is wider than a type 2 transmission so I assume I need shorter drive shafts but not sure what will work.
I also know I need to change the transmission end CV joint for a 915 style one but that is easy.
Anyone done this before? What drive shafts will work?
Porsche powered Bus and 915 Transmission
- ajdenette
Re: Porsche powered Bus and 915 Transmission
you should try to get some measurements to get a true idea of how much wider the transmission differential is and then look up the axle shaft lengths for bays, Vanagon's, type 4's, and porsch 944's. the Vanagons and I believe the bays used two different length axles on the Auto's so keep that in mind.
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
|_________oo_oo
/ /__/____[_____\
makes sense. I can measure my 915 but I no longer have the 1971 vw transmission. Anyone got one they could measure?
- Jadewombat
When I did the IRS swap on my bus I had to get custom axles. I used a bug IRS trans. and thing axles stubs (meaning I changed a lot of stuff around). I then measured cup to cup and subtracted 1/2".
Don't try to guesstimate. Measure what it actually is on your bus.
It was an offroad place I ordered the axles from. Can't remember the name, but it was reasonable.
Thanks, fro measuring it looks like 911 axles will work but will be checking and checking again
Is this finished?
How well did it go?
How well did it go?
