105mm Je pistons with cast cylinders for a daily driver
pnikas
Hello everybody , would you recommend 105mm JE pistons with cast iron cylinders(csp) set , with a 71mm crank for a daily driver? Will it be reliable ?
cal 67
Re: 105mm Je pistons with cast cylinders for a daily driver
You should use six studs to minimize deflection if using a stock casting. There may be other ways to seal, but six-studding is probably he most reliable way.
