Last summer I decided that its time for something else. Got too much used to the power my 1971cc type 4 made some years ago, so I sold the engine and started collecting parts and advise on a stroker build.
Everybody advised me to stay away from 86mm stroke, so I did as much research I could and bought a 86mm crank anyway.
At the moment the heads are being finished at the workshop which does all the machining (the double springs did not fit), and also sent the crank, flywheel and pulley for balancing, so I thought it was time to start a topic of this build.
The specs:
- 86mm stroke, 2.0l journals
- 104mm cylinders, the extended version, JE pistons (makes 2922cc
- h-beam rods
- VW heads, machined for the 104mm cylinders, 46x40mm valves, double springs
- Web 86c cam (1" base circle)
- 50mm throttlebodies
- MS2-extra, modified for sequential coil on plugs
- 911 cooling system
- Homebrew stainless steel exhaust
Time for some pictures:
The crank with rods:
Crank and cam inside the case:
All clearanced and bolted together with the heads:
VW Speedshop throttlebodies with Orratech manifolds:
First check how the engine fits in the car:
Building the exhaust:
Finished tack welded exhaust (at the moment my neighbour is working on welding the exhaust.) When the engine is assembled and fitted in the car I will make the muffler part.
For now I start with the standard 4 bolts/cylinder, and see how it works and deal with the (possible) sealing issues. I like the option of modifying the heads to 5 or 6 studs, but when I would modify it, I would first check out how head gaskets etc. will work, before I would do such a modification. If anyone has more info or good experience with studs, rings etc. please feel free to share information, also what your problems were without.
From my experience, so far it looks like its a working combo. If I would do it again, I would reconsider to buy a 86mm crank again. The reason is that its easier, and more lift on the cam is possible. Or I would choose for a cam with less lift and big ratio rockers to compensate..
Next job is finishing the case (cleaning and changing the oil plugs for NPT) and the 911 fanshroud, which was not wide enough.
Wish you all the best!
Mark
