craigdeb
Posts: 24 Joined: Mon Aug 29, 2005 2:34 pm
Post
by craigdeb » Sat May 02, 2020 1:09 am
Hi, I'm assembly my 2165 and have just attempted to torque the first of the heads down and, snap off came a stud!
I used Permatex reb thread locker on the thread when I assembled the studs so it's going to be next to impossible to get out!
Does anyone have experience in how I should remove the snapped thread? Should I use heat, some kind of pentetrating solvent?
Any advice is very welcome!
Thanks,
Craig
Sent from my VOG-L09 using Tapatalk
sideshow
Posts: 3428 Joined: Mon Oct 27, 2003 11:00 am
Post
by sideshow » Sat May 02, 2020 10:00 am
Loctite is designed to require heat to remove, its written on the package and should be considered the first step
66brm
Posts: 405 Joined: Mon Apr 12, 2010 6:55 pm
Post
by 66brm » Tue May 05, 2020 7:02 am
Since there's a fair bit of thread sticking up I would weld a nut onto it, it'll heat the stud at the same time and make it easier to remove
craigdeb
Post
by craigdeb » Wed May 13, 2020 1:49 am
Great thanks, that worked!
Bad Bob
Posts: 112 Joined: Wed Nov 12, 2014 10:47 pm
Post
by Bad Bob » Wed May 13, 2020 9:15 pm
If one snapped, I’d take a closer look at the rest. Maybe time for a new set.
Tom in PA
Posts: 639 Joined: Thu Aug 21, 2003 3:18 pm
Post
by Tom in PA » Tue May 19, 2020 8:03 am
I agree, if I had a stud snap when torqueing, I'd be super nervous...
Posts: 17881 Joined: Mon Nov 13, 2006 10:17 pm
Post
by Ol'fogasaurus » Tue May 19, 2020 9:36 am
Bad Bob wrote: ↑ Wed May 13, 2020 9:15 pm
Good idea. Fasteners do have life spans and you never know if someone, in the past, has overtightened one or all of the studs or bolts. Inspect all then act accordingly is a good idea most everywhere.
