(Installed picture is my buddy’s, his body is off and it took him 15 minutes to pull his old one off and put this on)
https://photos.app.goo.gl/5wBqVxrcx4RQg9c16
I’ve been lagging pretty hard on installing it. I’ve got a lotta stuff in the way (radiator, fuel lines, hydraulic clutch etc).
My first issue that is nobody’s fault, is that the later ghia? Spindles don’t have the same bolt pattern and spindle size for my brakes. I run airkewld’s BAD brakes with 4 piston wilwood calipers. I didn’t know this. Pete at airkewld is swapping me my spacers, I swapped the bearings, but He doesn’t make a caliper mounting kit for it, so I’ll have to make that myself. iMohr could have specified the spindles and I could have bought some other dropped ones that would work.
https://photos.app.goo.gl/mctikz5c2SCg8yux8
The only issue my buddy has had so far is that they sent him massive rod ends for the steering. Not sure why when stock is only 12mm, his look like they’re 3/4”.
My second issue so far are their spindles. The machining done on them has raised ribs around it. I had to do some sanding to be able to get the bearings on. One spindle also had pretty hard paint on it from the painted spindle assembly, but it needed sanding anyway so it wasn’t too bad.
https://photos.app.goo.gl/UH7fZYC32Y1kvFNK6
I may have some issues with my hydraulic clutch master cylinder, but that’s on me. I’ll try to figure out how to post pictures soon.
