Anyone doing 92mm thick wall forged piston/cylinder sets?
Sideswipe
Post by Sideswipe »
I'm having trouble finding a set of 92mm thick wall forged P&C's with 90.5 on the case side and 94mm on the head side for 76mm crank. Anyone know of a place that sells them? I've found a AA set in hypereutectic, but I'm a little nervous about using them with a turbo.
Lingwendil
Re: Anyone doing 92mm thick wall forged piston/cylinder sets?
Post by Lingwendil »
You may need to mix and match sets.
terryly
Post by terryly »
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
sideshow
Post by sideshow »
I sure like the idea of 94 tops/90 bottoms, I see them here https://www.cbperformance.com/product-p/1027.htm
You would probably want a long rod as tease appear to be B pistons
66brm
Post by 66brm »
The cb listing is hyper pistons
sideshow
Post by sideshow »
Well cast pistons are better in every way compared to small hard pistons. Until abusive NOS or boosted engines are the normal, you will probably have to custom order your special bore pistons.
