Long time lurker, first time poster
I have a bad camshaft gear on a stock 1300 single port rebuild.
I did the basic checking when I rebuild it, to see how much "walk" it gets and if it will pop out while turning the engine backward.
Seemed ok, but after less than 300km, it started to make an unusual noise at idle. I dismantle the engine and found wear spots on the cam bearings and marks on the outside tooths'gear.
Turned out the gear was bent and put axial load on the camshaft.
I still have the original camshaft with his gear and it make more sense to use a perfectly good parts that match than a chinese knockoff that don't. Removing it is not a problem, but how to reuse it on the new cam?
I thought to use button heads M8x1.0 10.9 bolts, but I don't know if is necessary to machine something out of the gear?
