1911 running rough
GARRICK.CLARK1
1911 running rough
Post by GARRICK.CLARK1 »
HI Guys, I have a 1911 ,the issue is it runs like the key is being switched on and off in quick succession . I've swopped the points and condenser for a new set.
I'm wondering if the 12 volt supply to the coil is shorting somehow. I can wire it from the battery as a test.
wreck
Re: 1911 running rough
Post by wreck »
just put a test light on the power side of the coil when it's running . It'll show if there is intermittent power to the coil . check the rotor arm , they can burn out .
dstar5000
Post by dstar5000 »
BUSHINGS IN CRAP 009'S.. GET A REAL DIZZY..
LET US KNOW....
DON
‎"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
of this presidency,".. Barack Obama January 21, 2009, 30 minutes before he signed the law
sealing all his personal information....
GARRICK.CLARK1
It turned out to be a faulty new distributor. Just swapped it for another used distributor and all is well. Spark must have have been jumping around inside the cap. I changed the condensor and points for another too.
