VW T25 Vanagon Injection manifold
Paul H
Post by Paul H »
Got the T25 Vanagon 2.1 WBX converted to modern sensors ready for the aftermarket ECU
Modern injectors with extended tip for better spray pattern,stainless fuel rails, MAP Air Temp sensor , Throttle position sensor
Chip Birks
Re: VW T25 Vanagon Injection manifold
Post by Chip Birks »
Looks nice
Michael1
Post by Michael1 »
Looks cool
Where did you get the fuel rails from?
panel
Post by panel »
Michael1 wrote: Sat Mar 20, 2021 12:42 am Looks cool
I think this is his site.
https://vwspeedshop.com/home.php?cat=395
Paul H
Post by Paul H »
Direct link here
https://vwspeedshop.com/product.php?pro ... 519&page=1
The fuel rails are stainless steel from the SP1 throttles I make which just happened to be the correct spacing and the conversion cups
were also something I already had of the correct size which convert the old rubber ring seal to the better 14mm O ring.
I suggest using injectors with extended tip for a way better spray pattern and similar flow rate to the originals good for 140hp at 3 bar.
There's quite a few out there now and they run very well -tuneable and serviceable especially with the extra alcohol in the fuel these days
