CB performance IDF 40 hats (and boost leaks)
Therealkoop
Does anyone have a solid solution for sealing these hats? If I dont get in there with a pick and perfectly position the gasket, the things leak profusely. Ive been fighting it for long enough that im looking for some solutions people may have created if they had the same problems. I just readjusted them again yesterday so it got me thinking about it.
split1950
Re: CB performance IDF 40 hats (and boost leaks)
You might not like the answer.....Therealkoop wrote: ↑Tue Jul 20, 2021 8:13 am Does anyone have a solid solution for sealing these hats? If I dont get in there with a pick and perfectly position the gasket, the things leak profusely. Ive been fighting it for long enough that im looking for some solutions people may have created if they had the same problems. I just readjusted them again yesterday so it got me thinking about it.
I am in the process of making new CNC bases with a decent O ring.
My bases were warped. I am hoping the hats themselves are usable.
By the weekend I should have them made, I will post pics if you like?
Therealkoop
Haha you are correct I do not like that answer. If you make them you should post them up! Sounds pretty sweet.
madmike
You won't like this one either,, ya can alway go 'draw threw"
- John S.
Maybe a machinist can plot out the shape and recut the channel.
GARRICK.CLARK1
Mine are OK. Can't see why yours leak. Put a straight edge across the bottom edge of the hat. See if it's square
Therealkoop
The CB ones always seem to migrate up into the carb and break the seal between the hat and the base. When I pull them out they are typically pretty warped.
I bought some 1/8th rubber sheet and cut my own gaskets out. They are a bit oversized and need to be pushed down into the base. I can wiggle the carb hat all over without them moving out of place, and they are sealed up better than they have ever been. It will take a while to see how they perform longer term.
split1950
Just got my custom / homemade CNC bases back from the anodiser - lovely job
At least these are flat and I decided to have an O ring between the TB and the base, hope it can handle the boost
- John S.
Those are nice. Wonder if weather strip adhesive would work on the CB gasket.
Therealkoop
Looks awesome
