Instructions don't quite stack up, or I can't make sense of it anyway...
CB say it uses a hall output, so that takes me to page 5.2.14.3 Adding a cam sensor input - hall or logic sensor
MS Extra says the output should be 0-5v. Is this the case?
Next it says red should be connected to switched live 5v to 16v, so I guess any switched 12v live off my relay board is fine, or 5v of TPSREF, and then grounded at the MS sensor ground. Which all makes sense, likely just supply 12v unless there's a good reason to use 5v?
This is the bit I don't get...
The blue wire- the signal- goes to TACHIN, pin 24. But that's where my crank trigger goes to.
How have people gone fully seq. with an MS2 v3.0?
Adding a CB cam sync
- Chip Birks
Re: Adding a CB cam sync
I didn't think that an MS2 was natively ready for a cam sync. Might need to add hardware.
UKLuke72
Yeah there's a few bits to add on the proto area, I can work with that. I think.
I need to make sure it doesn't interfere with my crank trigger though somehow
