This motor won't be used for drag racing, it might happen, but will 99.9% be used on the street by adults (wife).
There might be a couple hundred horsepower involved one day,
but we want it to be quiet, if possible.
The plan includes oiling tricks for long-time highway running.
When filling a box full of nice parts, we want to use the good stuff where it's needed.
Would it be better overall to start with a Rhino case and a pair of heavy-duty side covers,
Or would it be nearly as strong to use a later SSC, a.k.a. "Shift rib" and maybe a double-ring cover?
We do plan on putting in an IRS super diff, unless that might make things noisy or be a waste?
While the Rhino is aluminum vs. mag, the later cases have the bigger (better?) pinion bearing,
Plus, the integrated side cover is stronger too as well, right?
Heard somewhere that some of the Rhino cases have quality/dimension inaccuracies that might make them noisy when used long-term on the street.
All the Berg5s i see are built on Rhinos - is there a reason for that?
Let me know your thoughts, as I've never done Berg5 (yet).
Much thanks,
Steve
