Well since I just finished my aunt's dune buggy build I'm onto the next vw project which is my volksrod.
As the car currently sits
Motor-
Kaddie Shack 1914cc 108hp 116ft lb torque
Engle 125 cam
KS 40x35 round port heads (Empi heads)
KS kadrons
1.5 sidewinder style exhaust
Trans-
Kcr Pro street 4:11 w/.82 4th welded hubs ect.
Suspension-
Stock rear
Beam extension
Front disk brakes
I got the car a couple of years ago from a good friend of mine and I haven't done much to it besides put some different front seats so I could fit in the car, change oil and drive it! But now comes the time to do some upgrades!
I am going to take the dual kads off and put my dual 40 idfs w/ 32 vents from my 2058cc and also remove the 009 w/ pertronix for a compufire dis-ix w/009
I think that will be a nice little upgrade for this engine
So far the plan I have for this car is get the motor dialed in with the web's and compufire and eventually pull this motor out and put it in my wife's bug "Jolly Bug". Before I pull the motor out I'll have to build/revamp a motor for it, my supercharged 1641. I think that motor would be perfect for this car! As it sits that motor is slapped together with all of my used garbage parts with the exception of a new set of stock china heads with single high rev springs. It has a amr500 on it with a Rochester 1 barrel off a chevy 250 straight 6, I plan on rebuilding it with all parts I already have. So far I have a old(but in very good shape) cast 78mm stroker crank, 90.5 A pistons, vz25 cam, and the supercharger will get upgraded to a sc12. I will line bore and open up the case/heads at home when it comes time to build the engine.
Sent from my SM-N975U using Tapatalk
